Slow start
PaulC5
x 723
Re: Slow start
Unread post by PaulC5 »
If on starting the engine is not turning over as quickly as usual, maybe the battery voltage is now low, especially after all the attempts at starting with the fuel problem. Before starting first thing in the day I would check its voltage, should be about 12.7 volts but any lower than about 12.5 volts and it needs charging.
