1.6 e-hdi camshaft position sensor
- x 3298
Re: 1.6 e-hdi camshaft position sensor
Part of the design of the HDi cylinder head is that the valves are perpendicular. This should mean that they do not get bent (and the rocker arms take the load if a piston hits a valve), as the piston hits the valve squarely.
- x 1504
The usual failure on these is to strip the teeth round the crank pulley, which is pretty much what you are seeing. Will need a new cam, 8 rockers, new belt kit. Only if you are very unlucky will it have dropped a valve meaning head off. You had to do the belt anyway, so console yourself with the added cost is only about £400
- x 1083
Don't ever scare us like that again!!!! I thought it was the C5 that went wrong!!! You should be banned for scaring us! Secondly, never continue to try and start a car that was driving and then stopped, 9/10 a belt has snapped at it's gunna cause more damage
Champion of Where's CitroJim
c16rkc
- x 104
I was told by the garage it would be £550 just for the CAM belt, so I'm guessing that's parts only...?RichardW wrote: 30 Sep 2023, 18:23 The usual failure on these is to strip the teeth round the crank pulley, which is pretty much what you are seeing. Will need a new cam, 8 rockers, new belt kit. Only if you are very unlucky will it have dropped a valve meaning head off. You had to do the belt anyway, so console yourself with the added cost is only about £400![]()
c16rkc
- x 104
That's sounding good, do you think I should take to a Citroen specialist, or just a good reputable garage?Hell Razor5543 wrote: 30 Sep 2023, 17:15 Part of the design of the HDi cylinder head is that the valves are perpendicular. This should mean that they do not get bent (and the rocker arms take the load if a piston hits a valve), as the piston hits the valve squarely.
I ask because I spoke to our local Citroen specialist a few weeks back about this very car, and he advised me it was probably not worth having the CAM belt and upper strut bush done on such an old car. He said the combined cost would be around £1,000. I sensed in his voice he didn't really want to do the work, though I got a similar feeling about the C5 too. It makes me wonder if he's the best place to take an older car.
- x 1504
Don't know how far you are from Boston, DK Motor group there posted in the C4 Picasso FB group today about doing this very job on a blue hdi for £800 - they specialise in Picassos, but might well pick up other Citroens.
c16rkc
- x 104
Ha ha I have to apologise!Rp0thejester wrote: 30 Sep 2023, 18:33 Don't ever scare us like that again!!!! I thought it was the C5 that went wrong!!! You should be banned for scaring us! Secondly, never continue to try and start a car that was driving and then stopped, 9/10 a belt has snapped at it's gunna cause more damage
Luckily the C5 is running beautifully, and I am enjoying having it as my new daily driver. I'm pretty certain its a keeper and I have plenty of little modifications and upgrades planned for it.
Sounds like the little C3 will need a little money spending on it now though...
- x 1083
Just scrap the C3 and spend the money on the C5
c16rkc
- x 104
They are about an hour from me, so its touch and go really. I could always have it trailered I suppose.RichardW wrote: 30 Sep 2023, 19:08 Don't know how far you are from Boston, DK Motor group there posted in the C4 Picasso FB group today about doing this very job on a blue hdi for £800 - they specialise in Picassos, but might well pick up other Citroens.
c16rkc
- x 104
Oh my goodness... if my boys heard that
Jelly bean is the best car in the world to them.
Funny they don't see anything special about Lindsey's Audi, they show no interest in the Mercedes, but they are always asking if we can take the bean car.
We think it might be because they sit higher and can see out the windows better...
- x 1083
There'll soon be asking for the C5, scrap the C3, have you ever been in the back of a Citroen whilst in motion? Try it, it's sooooo comfy
- x 3298
I asked my local Citroen specialist to sort out my C5, and I got the same feeling that he was not interested. A friend told me about somebody who not only does mechanicing, they had their own workshop, worked for (at the time) GSF, and also went racing. I got the parts from ebay, and he (and his brother) got the C5 running. It was they who diagnosed the problem by removing the rocker cover and finding damaged rocker arms. I cannot remember the total cost, but as my C5 has the 2.2l HDi engine (twin turbo, 173HP when new) and quite a high spec level.c16rkc wrote: 30 Sep 2023, 19:06That's sounding good, do you think I should take to a Citroen specialist, or just a good reputable garage?Hell Razor5543 wrote: 30 Sep 2023, 17:15 Part of the design of the HDi cylinder head is that the valves are perpendicular. This should mean that they do not get bent (and the rocker arms take the load if a piston hits a valve), as the piston hits the valve squarely.
- x 1061
Unfortunately i have found the DV6/5 engines not as forgiving after a timing belt failure. The cam lobes are pressed on to the shaft & they often twist on the shaft. Seen plenty of them damage valves too. On the older DW10 8v engines i have never seen a single one damage a valve after a timing belt failure.
c16rkc
- x 104
I confess I do find the C5 very comfortable to drive - the kids fall asleep very easily in it and I can imagine I know whyRp0thejester wrote: 30 Sep 2023, 19:17 There'll soon be asking for the C5, scrap the C3, have you ever been in the back of a Citroen whilst in motion? Try it, it's sooooo comfy
c16rkc
- x 104
Thank you - I may well try and find a garage who is more interested then.Hell Razor5543 wrote: 30 Sep 2023, 19:24I asked my local Citroen specialist to sort out my C5, and I got the same feeling that he was not interested. A friend told me about somebody who not only does mechanicing, they had their own workshop, worked for (at the time) GSF, and also went racing. I got the parts from ebay, and he (and his brother) got the C5 running. It was they who diagnosed the problem by removing the rocker cover and finding damaged rocker arms. I cannot remember the total cost, but as my C5 has the 2.2l HDi engine (twin turbo, 173HP when new) and quite a high spec level.c16rkc wrote: 30 Sep 2023, 19:06That's sounding good, do you think I should take to a Citroen specialist, or just a good reputable garage?Hell Razor5543 wrote: 30 Sep 2023, 17:15 Part of the design of the HDi cylinder head is that the valves are perpendicular. This should mean that they do not get bent (and the rocker arms take the load if a piston hits a valve), as the piston hits the valve squarely.
