SD Card Clone (Nothing else)
This section is for General Enquiries or for Systems not Covered Above
x 1940
Re: SD Card Clone (Nothing else)
Unread post by Paul-R »
My bad. Mirascripts doesn't work so the only thing you can do is to clone the card as you originally asked. Which is exactly what I did before altering the partitions although I didn't keep the copy once I'd proved that the altered partition size worked on the original card.
Again, apologies for losing the plot a bit.
Gerry_123
Unread post by Gerry_123 »
Thank you for your time.
x 1940
I hope it was of some help to you.
Gerry_123
Yes, thank you.
Too close this out - cloned 3 partitions (in my case). For linux users (1) Disks & (2) GParted to tidy up.
For disassembly read 'https://peugeot-meeting.nl/forum/viewtopic.php?t=11169' & will add that the CD player must be removed for cable access. My thermal paste was more like cement & used a heat gun at sites (finger hot) to remove & again for reassembly. I like also cut a slot with a dremel for SD card later easy removal.
All works good. Thanks to All.
