C5 X7 front ride height sensor
Kees
x 148
Re: C5 X7 front ride height sensor
Unread post by Kees »
In this case, when people are working on the wishbone without looking how some parts are mounted/connect then special the 2.0 the link between the height sensor and stabilisator as changed without notice of the mechanic!!
The result is, the lever on the height sensor is in the wrong position that caused the the front of the car stays low,because the sensor tell the system he stands to high.
So the remedy is, disconnect the rod on the clamp on the stabiliser rod, turn the lever of the height sensor 90 degrees, and reconnect the rod back on the clamp.
