Gears won't go well?
x 2341
Re: Gears won't go well?
Unread post by MattBLancs »
CitroJim wrote: 08 Nov 2022, 18:47 20 litres of it would last me several lifetimes Matt but good to know it works fine in BE and ML 'boxes...
I thought so too, but found myself buying a second 5 litre tub soon enough! (Should have jumped straight to a 20 litre when doing the first one)
I always try and change gearbox oil when I change cars (admittedly this isn't often) invariably what comes out is generally pretty foul black stuff which makes me feel all the better for changing it - despite the stink of the stuff!
It's getting to the stage where I want to swap the driveshaft seals at same time as the box oil swap. Oh and grease the gear linkages. Oh and repaint that generally always rusty mild steel 5th gear cover housing on a BE box - easier to grind clean, then paint if taken off, so a fresh bit of RTV on that joint keeping the oil in too.
About this point I wonder where my weekend has disappeared too...
On the end of of a VW golf mk2 gearbox is a cover which is frankly a golden syrup tin lid but with a VW roundel in the centre (replacements priced significantly above Tate and Lyle's version, and sadly they are different diameters - I did check!). I scraped a load of accumulated muck off said lid. On my return home I found I couldn't get it easily into 1st as pulled into the driveway. Then I found the box dry and that dotted line along my route took weeks to fade! I don't think that would have done many miles without oil.
I have often read that 75W90 versus the correct 75W80 is a significantly downgrade in BE4 performance - though I have also seen numerous parts websites recommend 75W90 for these.
My reason for seeking out synthetic was that I believe it should hold its viscosity or rather not thicken up as much as a mineral equivalent at low temperatures. Don't have any quantifiable evidence of if that makes any difference in practice (or just being rid of the old black muck is an improvement enough in its own right)
Matt
x 5673
On another forum there was a girl posting as "90wt" as her husband said that she was thick.
(She wasn't thick at all).
x 1938
Unread post by Paul-R »
Should've been SAE130 surely?
x 2341
Ok, I'm going to try my up most to make this my last off-topic post on this discussion,
But, if we need to describe someone as thick and do so in terms of viscosity, then we need a nice big number in Redwood Seconds (35 second oil is paraffin, some of the stuff used in shipping I think has a rating in the thousands and at room temperature you can slice it with a knife!)
And the final, final off topic, can't really talk about viscosity without mentioning the world's longest running experiment: the pitch drop experiment:
https://en.wikipedia.org/wiki/Pitch_drop_experiment
x 8370
Matt, that's the best bits of 'off topic' I've seen on this forum for some while :D Interesting stuff... Keep it coming ;)
Reminds me, I must order some driveshaft/final drive seals for mine as I'll swap them when I need to do the driveshaft CV boots - one is looking a bit perished so time to do it before it splits...
I shall buy 5 litres as I have two cars that use it ;)
Theflyingpostman
x 3
Unread post by Theflyingpostman »
My gear link kits, after fitted all is good and robust not floppy any more and 1st gear go in nice.
x 2341
Excellent news, thanks for letting us know it's sorted :)
x 8370
Excellent news :D
