2007 407 HDi 2.7 diesel injectors leaks
Frenchiemech28
Re: 2007 407 HDi 2.7 diesel injectors leaks
Unread post by Frenchiemech28 »
Attachments below
Huskyxantia
x 906
Unread post by Huskyxantia »
407 wrote: 19 Aug 2022, 13:28 After having mixed results with replacing the O rings on the leak off pipe (eg fixed one injector and then another would start leaking), I bought a new leak off pipe and
The worst part is refitting the injector leak off retaining clips - I tied each one with a bit of fishing line so if I dropped (and I dropped a few a few times), I could find it again - worked a treat
brilliant idear
:-D
407
x 22
Unread post by 407 »
My brand new leak off pipe thermistor sensor decided to spring a diesel leak (eg diesel coming up thru the electrical fitting) so the new sensor only lasted 10K kms :)
Maybe something to do with the P0088 high pressure issue.
Fitted the old one off the old pipe and it is fine.
