C4 gp 1.6hdi wiring diagrams
x 1044
Re: C4 gp 1.6hdi wiring diagrams
Unread post by wheeler »
Using a piggy back fuse from the fusebox as you say is your best bet, only other option i would use is the power socket wiring in the centre console. I reckon the easiest option is the fuesbox though.
x 6956
I agree, stick to a suitable fused connection from the fuse box, or you could be inviting additional electrical problems with other equipment.
Engenia
Unread post by Engenia »
Which is why I was looking for a wiring diagram - to make sure I didn't cause any unwanted problems.
Thanks for your help, both of you. I'll take the obvious path.
Sponk
(Donor 2026)
Unread post by Sponk »
GiveMeABreak wrote: 23 Sep 2021, 18:48 I'll sort it - I've deleted the previous diagrams in lieu of these:
Injection
ESP
Hi Marc. Is this for an EDC16C34? If so, is 4050 the exhaust pressure sensor?
x 6956
If you want a diagram, pop your VIN up and I'll see if I have one specifically for your vehicle.
Sponk
(Donor 2026)
GiveMeABreak wrote: 04 Oct 2023, 21:57 If you want a diagram, pop your VIN up and I'll see if I have one specifically for your vehicle.
Sounds good, thanks🙂
Sponk
(Donor 2026)
Is this the same? viewtopic.php?t=61834
Says TED motor, where the one I'm looking for is 9HZ
x 6956
Please be patient, I've been out this morning. I'll put the correct one up shortly....
x 6956
Ok, so here are 2 diagrams. One for the particle filter system and one for the main injection:
Particle Filter
1341: particle filter differential pressure sensor /
1343: downstream exhaust gas high temperature sensor /
Injection
Sponk
(Donor 2026)
GiveMeABreak wrote: 05 Oct 2023, 12:55 Ok, so here are 2 diagrams. One for the particle filter system and one for the main injection:
Thank you very much 8-)
Sponk
(Donor 2026)
May I trouble you for one more VF3**************[VIN obfuscated, can be read by forum staff] only with pins to the ECU and maybe highlight lambda? Thank you.
x 6956
Sponk
(Donor 2026)
GiveMeABreak wrote: 17 Oct 2023, 17:44
So 1310 lambda?
x 6956
1310 Airflow Meter.
Diesels don't often have lambda sensors.
For a list of codes look here on the wiki - most are here and in sections of numerical hierarchy:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
Sponk
(Donor 2026)
GiveMeABreak wrote: 17 Oct 2023, 19:15 1310 Airflow Meter.
has a catalytic and particulate filter for a Peugeot 308 I 11-13 HDI 1.6 82KW (VF3**************[VIN obfuscated, can be read by forum staff]) Where the temperature sensor downstream sits between the two next to the inlet pressure pipe. There is then a hole at the top, before the catalytic converter, where a lambda probe fits. If it's not a lambda, what is it then?
Cat
Cat
