Peugeot 207 GTi Aircon issue
x 1481
Re: Peugeot 207 GTi Aircon issue
Unread post by xantia_v6 »
The underbonnet fuse box contains more than 10 relays, but they are soldered to the PCB under the fuses, they are not normally considered user serviceable, it is easier to replace the entire fusevbox.
The A/C clutch however, according to the diagram, does not appear to have a relay, it is driven directly by a transistor in the fuse box. The connection is on either pin 1 or 4 of the 5 way yellow connector on the fuse box.
Trainspark
Unread post by Trainspark »
Thankyou for your quick reply appreciated
