Cooling Fan Problem
Sheffwedfan
Re: Cooling Fan Problem
Unread post by Sheffwedfan »
Can anyone tell where the fan control module ecu is located on a 2017 c4 grand picasso facelift model is? I have p0693 and p0480 faults codes relating to cooling fan and the car is in limp mode with the service light on all the time ,had rac out he checked the fuses in the engine fuse box and all ok he suggested I change the ecu on top of the radiator shroud,still the same,I then bought a 2nd hand radiator fan plugged that and still the same after reading posts that's why I'm thinking the fan module ecu but I carnt find it anywhere thanks in advance
Sheffwedfan
I have a 2017 c4 grand picasso facelift model,the car is in limp mode with fault codes p0693 and p0480, all fuses ok no broken wires,I changed the ecu at the top of the radiator shroud and tried a different engine cooling fan but still got the codes so after googling it it maybe the cooling fan module ecu but I carnt seem to find it anywhere so can anyone tell the location? Thanks in advance
