Condensation
x 5673
Re: Condensation
I used to be forever clearing the C5 scuttle as I always have to park under trees. Loads of cherries and spinny-jinny's.
Went to do the same with the Civic and they have done it differently, self cleaning :)
I'm sure they have left different traps for the unwary.
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: Condensation
Try leaving your Heater vents open and the Heater settings on cold so that air can (possibly) get in and circulate, depending on the design of the system; see if it helps
Puxa
slackgarry
Re: Condensation
Unread post by slackgarry »
Hi guys were are the scuttle drains on a 2008 C1 please ...
Kind regards
SlackGarry
Black 2008 C1, Petrol, 1KR-FE Engine. aka the GoKart
x 6945
Re: Condensation
You need to remove the wiper arms first then the trim - you'll find the main drain hole on the left as you stand facing the windscreen - seen at about time index 1:21
Have a look at this video:
slackgarry
Re: Condensation
GiveMeABreak wrote: 02 Feb 2021, 19:40 You need to remove the wiper arms first then the trim - you'll find the main drain hole on the left as you stand facing the windscreen - seen at about time index 1:21
Thanks for that. Amazing.
Kind regards
SlackGarry
