Finally - clutch clip gone - SOLVED
debutant
Unread post by debutant »
Gonna have another look WHEN I have fixed the bl@@dy clutch clip myself! I am not prepared to pay the Cit garage the kind of money they want, if I can buy the clip for £7 and put my own time in[:)]!
Cheers,
John
P.S. hope I can do it [V]
AndersDK
Unread post by AndersDK »
Of course you can do it John -
You took the first VERY important step : you decided to do it [8D]
- it's impressive what you can do, when you are determined on the job [}:)]
- despite the cursings & trials while you're there [8)]
x 1439
John,
Most important is probably to remember to take a new bolt, 'cos after you've sawn the old one off you need something to put the pedal back on with... Also wire brush and wd-40 to clean / free up the adjuster on the clutch cable - you need a 10 and 12mm spanner for this as well I think. T20 (I think?) torx bit to remove the lower trim panel. Variety of screwdrivers and pliers / cutters.
debutant
All,
Thanks for the help! I managed this morning in about 4 hours to do the job myself [:I]
It took 3 hours to get the pedal (and bolt out) and 1 to fit it all together again.
Obviously the bolt was the problem but I managed to get it out without sawing the head off. I lowered the brake pedal by taking the plastic spring holder out, then a bit of metal bending on the left side of the clutch pedal and all of the sudden the bolt just came out [^]. I refitted the bolt the proper way and the car is fine again [:D]
Next time I have a problem I will try to resolve it myself (if it doesn't get too technical) instead of giving the money to CIT garages!
Cheers,
John
philhoward
Unread post by philhoward »
Keep at it...Cits are cheap to run cars if you manage to keep away from dealers (apart from the odd part that GSF don't stock..).
Well done!
debutant
Sorry, another question ... I was looking for a new clutch cable on GSF but which one do I need? Mine doesn't seem to be there?
Xantia 1.8i desire
107k miles
R reg (1997)
