Someone help figure out the diagram of this fuse box ?
- x 6957
Re: Someone help figure out the diagram of this fuse box ?
So it should be the lower relay of the 2 according to the diagram. This one controls the wiper timings - so you might want to try and replace that to eliminate that as the problem.
introfusion123
I'm searching for a new one , I'm coming when. I make the replace with a update
- x 6957
At least the relays are quite cheap to buy and will at least rule that problem out.
- x 1459
If I remember correctly, an identical relay is mounted in the tailgate to control the rear wiper.
