C5 X7 2.0HDI P1490 (FAP overloaded) - SOLVED!
XUD9
x 6
Re: C5 X7 2.0HDI P1490 (FAP overloaded) - SOLVED!
Unread post by XUD9 »
Hello,
Fortunately everything is fine.
Maybe I'm not getting the full distance between regenerations like with new FAP, but still the average is around ~600km (last 10) .
The most important is that there are no errors, and it runs smoothly for just 6 minutes every time.
PP: There was just 1 regeneration, that took around 20 minutes. Maybe it ran for so long because of the city traffic and the low speed, who knows. But there were no errors.
Mares
x 3
Unread post by Mares »
Hi, where do you find the status of FAP in Lexia?
My 2011. DS5 2.0HDI 160hp started to trigger quite often codes P0471 and P1490 related to FAP filter.
Not sure if cleaning is a must or just a sensor (related to P0471) is triggering both codes?
Here is the report from Lexia: https://easyupload.io/8wngwy
x 6950
Look in the engine ECU live data
Mares
x 3
Ok, here are readings from my Lexia while in idle. Any comment? https://easyupload.io/un58jp
My service shop said only cleaning of FAP would solve this issue. It is not about the cost (120eur) but the question is how efficient are those cleanings (not sure if it is decarbonisation method, or there are several ways to do this).
x 6950
Please upload your pictures to the Forum directly using the Full Post Editor & Preview Button, then the attachments tab to browse , upload and place your images. People are going to be reluctant to download anything from external links.
Cleaning is never going to be 100% as good as a new filter as there are microscopic particles in the honeycomb that will not be removed. It can prolong the life of the filter though.
LSF
Unread post by LSF »
Hello Ivo? Can we contact you to discuss something regarding the same problems I have with my Peugeot. I am from Bulgaria and I am happy to contact you.
osx
(Donor 2022)
x 15
Unread post by osx »
myglaren wrote: 09 Sep 2020, 19:32 That's an awful lot of €uros!
Got mine for £120 - let's see if it outlives the car!
C5 X7 Exclusive 2.0 HDi Auto
