I can confirm that after a full day today changing the battery and replacing starter motor, I found that the earth cable was attached by only the plastic heat shrink sheaf and when I pulled it, it broke. I made a new connection and bam, the car started. Honestly everyone, check that earth cable, even if it looks like it’s attached. A little tug on it should not break this cable ever, if it does break, there is your issue.mike_2001 wrote: 07 Jan 2020, 13:16 Hi guys
I found the issue. It was the gearbox ground cable. It was broken next to the gearbox end.
Now I need to replace this cable. The part number is 9677717680.
The question is: After I replace the broken cable I need Diagbox for checking and deleting the possible errors? Until now I couldn't find anyone with Diagbox.
On the eBay, the Diagbox software is 40-100 pounds. Is working?
I found this because after I checked all the fuses (all OK), I start to check the wires.
Thank you so much for your help.
Thank you Mike. Life saver. Good luck everyone.
