Citroen C5 X7 ECU communication problems
x 6950
Re: Citroen C5 X7 ECU communication problems
You can't just replace it!
The Engine ECU, like the BSI are paired once initially programmed at the factory as a set along with the transponders. If you attempt to replace the engine ECU with a used one it will not start. The only way to do this is to have either a new one where it will be configured and paired by a dealer, or to obtain the exact same part from a donor vehicle and send it off to have it wiped. You will still need to have it programmed and paired though.....
Gogeir
Unread post by Gogeir »
Oki, Thanks for the reply
My garage will wipe and clone.
But in my VF7**************[VIN obfuscated, can be read by forum staff] should a donor from VF7**************[VIN obfuscated, can be read by forum staff] work ?
It has 9HR insted of my 9HL and a automatic instead of my manual .
x 6950
No these have different ECUs
