C4GP radio wiring
tomaskriv
- (Donor 2026)
- x 6
Re: C4GP radio wiring
That's it. Now you gave me last bit of info that I was looking. THANK YOU SIR for your time and help.
P.S. Where do you get all this info?
- x 6945
Good luck with the job - you should be able to set aside a few months now for the easy bit!
admiral51
- (Donor 2026)
- x 391
Marc has the Force that's all we know and we ask no moretomaskriv wrote: 22 Oct 2019, 14:56 That's it. Now you gave me last bit of info that I was looking. THANK YOU SIR for your time and help.
tomaskriv
- (Donor 2026)
- x 6
All done and working. Again big thanks for help.
- x 6945
No problem - thanks for letting us know the outcome.
MelC4
Hi will this wiring diagram for radio and speakers work for my 2013 C4 Ehdi.
- x 6945
No Mel, it may be similar in some regards, but diagrams are specific to vehicle, build year, engine, specific equipment and options fitted.
This is the diagram for your C4 with specific options:
MelC4
Thank you Marc is there any RCA connections on my radio to connect an amp if not where can I connect the speakers to an amp and sub woofers at the back of the car as all my speakers are in the doors.
- x 6945
No. Factory fitted Amps have different wiring, sometimes speakers and an interface between the head unit and the amp.
On the C4 B7 with the HiFi option, the Bass loudspaker enclosure located in the rear boot right side incorporates the Equaliser unit. In addition the HiFi factory option included additional speakers.
So you cant' really retrofit one of these without replacing the wiring and fitting the additional speakers and all the kit as well as the configuration and wiring to the fuse box.
Your best option is to buy an aftermarket amplifier using a Line Out Converter (LOC) to convert the high output signals from the RD5 Head Unit to the LOC which converts these to low output prior to connecting to an amplifier. Some amps even do this for you - so it all depends, but it's a project you'd need to research first.
MelC4
Thank you Marc my amp has one of that LOC unit next to it, I do not have that speaker at the rear right side of the boot will the wires be there for that speaker I did wire up a C4 torch there and seen a lot of wires there.
- x 6945
According to your VIN you don't have the factory system HiFi system installed, so there's no amp or Loudspeaker unit or wiring fitted. It's a different loom and additional wiring Mel, so not sure what you are referring to regarding your amp. It's either aftermarket equipment or something else.
MelC4
Ok all good thanks I have an aftermarket amp so just have to wire it to fuse box and locate wires from the radio head unit.
- x 6945
Obviously I can't help you with aftermarket systems Mel as they are all different in capabilities wiring, but you can locate the speaker inputs from the diagram I provided.
MelC4
Hi Marc all good thank for the help I just have to locate that speakers wires and I should be good.
MelC4
Hi Marc, what kind of sump plug washer & size does my 2013 EdhiC4 use.
