god, i am getting very confused now. been going thru the searches for old topis on gear box oil....
i am popping in a BE 3 box to replace the slush box in my Xantia ,
so far i poured in Esso BV 75W-80 oil to sort of flush and clean it.
haven't driven the car yet, but i intend to change to synthetic oil Redline MT90...already bought 3 quarts of these .......
i wana hear from those who have had bad experiences using oils other than the Esso Total BV CORRECT oil in these boxes.
permanent damage? whining diff? notchy shift?
cheers.
Gear box oil
davek-uk
I used the wrong oil when I replaced my gearoil. I used an 80W/90 GL5 oil. That was 40-odd K miles ago now. Appears to have done no damage but initially the gearchange was 'heavier' - seemed slow and thick! I would have changed it there and then but with Slick 50 in it was an expensive task. Anyway, I've got used to the thick shift; either that or it has become better.
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
jeremy
If you search here you'll find remarkable few incidences of gearbox problems and I think the general consensus is that whats recomended will do a perfectly good job and that there's little point in putting in anything else.
Some people have favorable experiences with additives which seem better for gearboxes than engines
jeremy
