307 2.0hdi misfire
Simple76
x 9
Re: 307 2.0hdi misfire
Post by Simple76 »
Do you have any problems starting vehicle?.
Christopher Robin
Post by Christopher Robin »
Mine would start ok.
if left would tick over ok.
if you tried to rev it, then you got this kind of flat misfire, bit like the old days with petrol engines and choke, if you pushed it in to quick you ended up with this flat misfire where it was getting to much cold air to fuel.
on the HDi this would last for a couple of pedal down revs then she was fine, but you did get black smoke out of the back of her during this revving process. No fault shown for this.
Had an air temp fault --- changed.
Had a turbo boost pressure fault -- solenoid changed.
Turbo issue (stuck Vanes) -- Changed turbo.
Finally Crank position Sensor -- Changed (this is the only job done which stopped the initial start up misfire)
For now!
does still have a very annoying wheel wobble at 70mph.
Changed ALL wheels to brand new OZ wheels, also changed tyres
Changed Driver Drive shaft + intermediate bearing.
Changed Passenger Drive shaft
Changed driver wheel bearing.
Still there, seems when you jack it up and drop it down, wobble goes, but returns a day or so later always at 70, through to about almost 80mph every time.
still at drawing board for that one.
