Citroen c5 boot fails to close
x 2345
Re: Citroen c5 boot fails to close
Unread post by MattBLancs »
An interesting topic, my electric boot often stops about half way back down. Two beeps. Push the boot close button again, heads back up, push again, down again and closes no issue.
If I "assist it" just a little with slight hand pressure then shuts on the first trip down.
I (correctly or incorrectly!?) Deduced this to mean too much resistance in the drive system/ cables is triggered the perceived obstacles detection. Interesting others have had it apart, I thought of asking about stripping this down but assumed from Citroen perspective it's full motor + cables that get swapped (much like elec handbrake) so assumed there'd be no guide on disassembly of the unit into sub components.
I also get Economy Mode Active disabling the boot closing if has been opened for long periods. Manual coursing in this case then does get the catch to engage without issue - different to what reported by others.
Oh for a mechanical boot catch (linked to a mechanical button with a metal rod) and a pair of gas struts!! :-D
