Ok, Cool. That's good to know. Thanks.
David.
Rely 2.2 cuts out when turbo lifts
DHallworth
- x 161
Re: Rely 2.2 cuts out when turbo lifts
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Fra21r+
Free day today so thought I would have another look at the van
David is on holiday till next week so hopefully he can come and plug his lexia kit in and see what up
Though I'd do a leak down test at idle for 5 minutes number three seemed a lot fuller than 1,2 and 4
Change numbers 3 injector still the same
Time to wait for lexia me thinks
I indent keeping the van would it be worth while buying my own, pros and cons?
I see there is a discount code for easy diagnostic
Fras
Fras
Fra21r+
Injector fualt. now sorted
ekjdm14
- x 263
Glad to hear that's sorted, on the Lexia thing I'd say it's definitely worth having the kit if you're going to keep the van for a good while. Not least because you have instant access to any future issues that crop up, plus you can change config if you decide to upgrade/replace parts (injectors I think would come under this too). There was a used kit already on a laptop in the for sale section recently, not sure if its still available.
(Also you then have the capacity to diagnose any other PSA vehicles you may run across with problems)
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
Fra21r+
Yeah seen the one for sale but won't post
il get it from easy diagnostic as they have support,
by all accounts it's a bit fiddley to install, managed to get an old Windows 7 laptop for free from a mate
Il have a good look here and
Just need to watch a lot of you tube and remember not to change any values with out taking screen shots first
Fras s
Fras s
ekjdm14
- x 263
Ah yes, location could be a problem with that one
didn't realise.
Yes the install can be a pain, especially before I'd done a full-on factory reset on the computer (just deleting all other programs didn't leave it "clean" enough) the actual diagbox software on mine wasn't so much an issue but getting the USB driver to stay correct and not revert to one that doesn't support the VCI box was the issue for me (I think the main key there is to stick to one USB slot and don't plug into any others).
As long as the windows version you have is 32 bit and taken right back to factory settings it ought to be fine, and like you say Easy have good support if you run into any problems. As far as screenshots, it's a good idea but I found once I got into it things weren't as scary as they sound to start with. Best of luck with it & hope it's as useful as it has been for us.
