Creaking ****** doors!
milleplod
x 15
Re: Creaking ****** doors!
Unread post by milleplod »
GiveMeABreak wrote: 08 Sep 2017, 09:03 That’s good news about the knees Pete, but what about the doors?
:rofl2:
I wish! I fitted a set of iridium plugs to the bike after lubing the doors - I could hardly get up after 15 mins kneeling! I really don't rate this ageing thing..... :evil:
Pete
Nocto Diuque Venamur.
x 6950
I know, I’m off out to get some more fence panels positioned and I can hardly walk after the last lot I put in!
EDC5
x 130
Unread post by EDC5 »
Right, I bought some silicone spray (the WD-40 stuff as halfords had sold out of their own stuff :evil: ) but I'm still getting the clicking at each 'notch' of the doors opening, not sure where else I need to grease?
x 6950
I know you've just had to pay out double for the WD stuff, but maybe you're scrimping Elis! :rofl2:
It's hammering it down here (again) so I;ll have to wait until it's stopped before I go out and test to see if it is normal to have the positioning click sound - I can't remember from memory!
EDC5
x 130
To be honest It'll take me a decade to use a can so I shouldn't complain really 8-)
I know there should be position clicks but this is excessive, I remember my old 306 car did the same as the mechanism that caused the clicks would become really stiff and 'bang' between the notches not smoothly run.... It's nice to see that 10 years later and PSA haven't changed :lol:
Also I feel as if the drivers door has dropped a mm or two over the years, is there an easy way to adjust it up slightly as the door (or latch) seems to hit something just before closing.
x 6950
Must be those suitcase-sized speakers you've just installed - I'll have a look...
x 6950
Ok, the doors are indexed on the door side (flushness) and on the body side (for clearances), but you'll need to drive the pins out first if you need to adjust it. It sounds quite fiddly, but shout if you want the procedure.
EDC5
x 130
Ah, it;s encouraging that there is a procedure at least!, yeah that would be great to look over. Its quite common for the door to drop apparently, especially as my car seems to have only ever been used by a single driver in the past.
Yup those speakers probably weight about 10x as much as the stock ones :lol:
x 3298
Just as well you have a Citroen then, otherwise you might find the leaning into corners to be a bit unusual! :D
EDC5
x 130
Hell Razor5543 wrote: 10 Sep 2017, 16:39 Just as well you have a Citroen then, otherwise you might find the leaning into corners to be a bit unusual! :D
True, what catches me off guard is when I think the hydractive solenoids are going to close for a particular corner... then they don't and I feel as if the car is going to roll over :lol:
x 6950
EDC5 wrote: 10 Sep 2017, 16:31 Ah, it;s encouraging that there is a procedure at least!, yeah that would be great to look over.
Rwyf newydd ei anfon
x 3298
x 6950
I've just told him I've sent it James.
x 3298
Those Ws and Ys ought to have given me the hint!
EDC5
x 130
Bendigedig! Diolch yn fawr Marc!
