DISPATCH 2.0 HDi immobiliser problem
lancia58
(Donor 2022)
x 8
Re: DISPATCH 2.0 HDi immobiliser problem - Solved
Unread post by lancia58 »
I looked at the electrical components that are mounted on the CPH board trying to identify the chip that stores the immobilizer code. I found a none volatile memory device ( serial FLASH of 500 bytes ) that I suspected it holds the code. Using a fine soldering iron I removed it from the faulty CPH ( the one that originally came with the car ) and solder it on the good CPH that I removed from a wracked Dispatch. Then I started the engine it turned on and runs OK. Thank you all for your help
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 3298
Well done on that.
Ulsterdavy1
Unread post by Ulsterdavy1 »
Hi guys my red light for alarm does not work my central locking only works when key is put in a door key does not respond when pressed battery is good in key any help on this thanks
x 1060
Unread post by wheeler »
Does the van still start?
Has the remote been tested to see if its transmitting a signal?
