No cranking ECU communication error Citroen C5 1.6HDI
davie206
Re: No cranking ECU communication error Citroen C5 1.6HDI
Im thinking this is either a fault with the bsi or abs module
AnthonyKnight
- x 5
Hi, did you manage to sort this problem, and found out what was the cause, because i have the same problem and still can't find what it is .
Matty223
Any luck fixing thisAnthonyKnight wrote: 02 Sep 2022, 20:49Hi, did you manage to sort this problem, and found out what was the cause, because i have the same problem and still can't find what it is .
