Subframe removal
x 8312
Re: Subframe removal
Sorry Kenny, no the HDi does not.. I was thinking you had a 1.9TD...
My bad... But yes, if the fans are on all the time that's the basic problem...
Great that you've sorted the height problem and all else looks good. :D
harryp
(Donor 2022)
x 73
Unread post by harryp »
IIRC the Stop and Temp lights also come on (HDI) if there is a fault on/with the relays in the triangular box in front of the fans if the air con is called, either on switch or on de-mist. HTH
Regards
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
KennyW
x 164
Unread post by KennyW »
Thanks for the reply Harry,
I had much fun a few years back tracing an electrical problem with my fans in the 1.9TD, so I will have to get the multi meter out and start testing and cleaning all connections.
It shall be fun in this weather!!!!!!!!!!!!!!!
Kenny
C3 1.4 petrol (SWMBO)
x 8312
Kenny, I have the HDi-specific wiring diagrams if you need them...
KennyW
x 164
Jim,
Send me the diagrams.
Kenny
x 8312
A please would have been nice Kenny :evil:
I'll forgive you just this one time :wink:
Here they are:
Cooling Fans Circuit
Cooling Fans Harness
Engine ECU Circuit
Engine ECU harnesses
Sorry for the poor quality, the originals were printed on paper that makes recycled bog roll look high quality!!!
Hope they help...
KennyW
x 164
Sorry jim forgot to say please, I have access to sedre but couldn't find the wiring diagrams.
so your links are great.
Kenny
x 8312
No worries at all Kenny :-D
KennyW wrote: your links are great.
Good stuff :) Fingers crossed they'll help sort the problem [-o<
KennyW
x 164
Jim,
Problem found burnt out right hand relay shorted between pins 4 and 5 !!!!!!!!!!!!!!!!!!!!!
Kenny
x 8312
KennyW wrote:Jim,
Kenny
Great stuff :D
Have you replaced it and is the relay base OK?
KennyW
x 164
Jim,
I've got replacements galore but I'm going to check the relay base.
Interestingly, the relay is a 5 pin but on wiring diagram it is 4 pin.I've 2 4pin relays spare which are new from TD. Also I see the secondary supply for hhigh speed mode is run throught the double injection relay.
Kenny
x 8312
As long as the base is OK for it there is no problem in using a five pin relay as a four pin replacement Kenny... The five pin is a changeover relay with a normally open and a normally closed contact whereas a 4 pin only has a normally open contact...
KennyW
x 164
Jim,
I couldn't get the forum until now, no idea why. But moving on..........................
The 5 pin change over relay shorted across pins number 4 & 5 melted down!
The relay base is the only one not smothered in grease.
Kenny
x 8312
We had an Internet bearer fail to the forum servers Kenny, all good again now...
KennyW
x 164
Time for an update.
All the little niggles fixed.
I have 1 rattle at start up and switching off which I believe is my return pipe from steering pinion as the pipe'.s loose but the pipe end feels secure. I think it needs a final tweek.
Otherwise its running fine.
The standard bubble flares for the front brakes are not leaking. So anybody needing to replace them can get them made up.
Kenny
