Hi Jim
When programming a key the CPH transmits to the key the RF code and the key stores it on a none volatile memory , or the key transmits its factory programmed RF code to the CPH and from now on the CPH allows that key to lock/unlock the doors ?
Zohar
Xantia - Central locking ECU questions
lancia58
- x 8
Re: Xantia - Central locking ECU questions
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 8406
I believe that is how it works Zohar.. The key has a chip in it and that's the bit that's programmed by the CPH...lancia58 wrote:the key transmits its factory programmed RF code to the CPH and from now on the CPH allows that key to lock/unlock the doors ?
I also believe the key transmits a different code on each use - a so-called 'rolling code'. The CPH knows in advance what the next code will be, in fact it knows in advance what the next 50 or so codes will be to guard against loss of synchronisation should the plip buttons be pressed well outside the range of the car receiver...
