My turn for a C5!
Bandit12
x 12
Re: My turn for a C5!
Unread post by Bandit12 »
Hi, I've a C5 estate and will happily measure wipers etc up for you and post replies this evening. Please let me know exactly what it is you want measured, is it just the length of the wiper blade or distance between ends of the blade and the edge of the glass etc?
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
x 3296
From the tip of the wiper blade, along the blade and arm, to the other side of the central hub/release unit please. Thanks. I am checking to see if the wiper and arm I have is correct in its' length.
Bandit12
x 12
No worries mate. Ill post the answers this evening.
x 3296
Thanks.
Bandit12
x 12
Ok measurements as follows;
wiper blade from tip to tip is 11.5 inches
wiper blade tip to centre of arm and hub is 15 inches
horizontal line from wiper tip to edge of the glass is 10.5inches.
Hope that helps :)
x 3296
Thanks again, it does.
x 3296
OK, I have made some progress (and the C5 herself is helping; she has stopped complaining about the EGR valve!). However, I need help on a few minor things.
1, Is there an easy way to find out if the brake pedal has the switch required for cruise control (oh, and where is the damned thing anyway)?
2, What is needed (barring the security code) to replace the radio (the one currently fitted plays up a lot), with one of the same type? I know you have to code it to the chassis.
3, I know that somebody explained how to clean the safety belt so they retract properly, but I cannot remember who it was. If anybody can remember, can you point me in the right direction please?
If anybody is after any bits, Wokingham Car Spares have a 52 2.2 HDi 16V C5 Exclusive saloon with leather seats, and they look OK. These people don't take the mickey over prices. They also have a MKII C5 saloon, but I didn't take a good look at it.
dnsey
x 19
Unread post by dnsey »
Before changing your radio, make sure that the aerial isn't faulty. The amp in the base is very vulnerable to water ingress.
x 3296
I know that the radio is definitely at fault. You have to mash the power button a load of times for it to switch on/off. The volume control isn't great, but I think that this was because somebody tried to fix the control, not knowing it was the stalk at fault (the stalk has been replaced).
x 5672
Do you mean the volume control on the stalk or the one on the radio itself James?
I just leave mine on all the time, control it from the stalk - since I discovered the volume control buttons on the back (in my brother's 307, accidentally :9 )
x 3296
The volume control on the radio itself. The original stalk was faulty, in that whenever you touched the volume control it went straight to maximum volume! Now that has been replaced I can use the radio, but it still has issues, which is why I have got a replacement one.
x 3296
Well, I have replaced the radio, and now I can switch it off without needing to hit the button with a hammer. OK, according to my Lexia there is an aerial issue, but I am aware that these can have problems.
However, I still need help on the other 2 items. Where is the switch on the brake pedal (to allow me to use cruise control), and is there an easy way to find out if I have one already fitted? How can I clean the drivers safety belt so that it retracts properly (I know somebody has done it on the forum, and written it up, but I cannot remember who)?
x 1996
Unread post by Stickyfinger »
I used silicon spray on the belt after fully pulling it out and applying a hoover nozzel.....my present C5x7 is also now suffering this as well, it even has the same "Awww sh17.... I have slammed it in the door" habit
Xantidote
x 4
Unread post by Xantidote »
Hell Razor5543 wrote:I know somebody has done it on the forum, and written it up, but I cannot remember who
Might have been me, but Stickyfinger's beaten me to it. As he says, silicon spray, which I bought as "Dry Lube", probably from a general household store. The aerosol canister says it's for hinges, locks, curtain tracks, as well as lubrication/protection use in the garden, workshop, boat etc
Martin
1995 Xantia TDLX (deceased :( )
x 1996
yep, that's the stuff. I go mine in Tesco.
Just do not spray it anywhere near a paint booth, you WILL be lynched :)
