£50 if you DIY it.....err, obviously.
Best of luck with your gamble, you are a braver man than me.
1997 xantia leaking radiator
- x 1995
Re: 1997 xantia leaking radiator
wurlycorner
- x 271
Absolutely correct with this, from my personal experience.Zelandeth wrote:Just bear in mind that if you've got the bayonet fitting hoses at the moment that chances are that you'll destroy them getting them off. So it would be sensible to buy a new top and bottom hose along with the radiator ready to change. Also saves you the massive hassle of trying to detach said hoses from the radiator in one piece which I can tell you from prior experience is at best a maddening experience in most cases. This usually ends up with you destroying the hoses anyway, your knuckles, and several bits of equipment in the general vicinity.
However... A new radiator will be easy to find (and relatively cheap). Give Malcolm Lockwood a call and he can sort you out.
As for the rad hoses though...? Good luck finding some of those!
Iain
CX DTR T2 Safari (silver)
Iain
redzzed
..and what happened ? after refilling the rad. 2/3 times over a period of time , the heavy leak stopped and i no longer needed to regularly fillup.Put it into my indi garage and he found a T hose leaking , he ordered and new one but had trouble removing the old .
In trying the radiator started to leak again .
The heater also seems to have blocked up.
We discussed it and agreed to fit a new rad. which he ordererd and got for about £90 , the wrong one arrived which caused a 3 day delay (i had a courtesey van).He left all hoses soaking/sprayed with wd40.
we needed a new top hose and also the filler cap seal was duff . He replaced all and ran the car up to temp.
one of the new hose connections started leaking and he used hose seal or something .
he filed up again and added anti freeze , and i got the car back , runs like a dream .
the heater is only slightly warm.
the hoses he says he got from citroen and one was £49.
cost me £358 which is less than i expected .
at one point i had an R reg Zx td lined up and it went for only £260 , but it would have needed all belts doing .
unfortunately i'm living entirely off savings otherwise i would have scrapped and bought a newer car , but thats another story .
thats all
puff
thats all
puff
current : 1997 xantia 1.9 td sx a/c
previous cars :
1997 zx memphis td
1996 zx volcane td
1994 zx volcane td
previous cars :
1997 zx memphis td
1996 zx volcane td
1994 zx volcane td
- x 1995
You have most likely blocked your heater matrix with the rad seal.....oil coolers on gearboxes suffer the same problem.The heater also seems to have blocked up.
http://www.frenchcarforum.co.uk/forum/v ... &view=next
Glad it never let you down and its now working.
wurlycorner
- x 271
Glad it's sorted for you.
But yep, my thoughts are the same - rad seal does tend to block heater matrix's unfortunately.
Iain
Iain
isisalar
- x 3
This stuff looks very promising, anyone tried it? Their other products are fantastic.
http://www.ct1ltd.com/en/miracle-seals.html" onclick="window.open(this.href);return false;
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
