It's all here on my website StickyStickyfinger wrote: (Jim.....no idea how the hell you get the bush out of the ram when it is on the car........given up, have to wait for pipe seals now....grrrrr bad day)
Rear Suspenders Bump Stop now NFP
- x 8386
Re: Rear Suspenders Bump Stop now NFP
- x 2001
Followed that, but I don't have three hands , to hold ram/operate bush puller....friend down today to assist
- x 8386
One thing to be aware Sticky, is that the original bush is a jolly tight fit in the ram eye, hence needing mandrels or a press to do the job...
- x 2001
boy oh boy, do I know that !
.....its hard with it hanging off and with only two hands and a strap to help keep the swing off the feed pipes ..........I failed...called for help (hate that !)
- x 8386
I turned up one of the mandrels I use on the lathe but if you have a good assortment of sockets and a length of threaded bar and thick washers you'll be fine...
Chris570
- x 36
Mine just fell out.CitroJim wrote:I turned up one of the mandrels I use on the lathe but if you have a good assortment of sockets and a length of threaded bar and thick washers you'll be fine...
It was knocking a fair bit though
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
