Xantia pull-type clutch principles
x 94
Re: Xantia pull-type clutch principles
Unread post by citronut »
Cornishcitroen wrote: The cable run doesn't look too bad around the front of the engine. At least the curves aren't any worse than the standard layout.
i would have thought it is more as it leaves the bulkhead toward the front ( cam belt end of engine ) it will be a very tight bend
Regards, malcolm.
Cornishcitroen
Unread post by Cornishcitroen »
Excellent! This has got to be the last part I'll need for this project...
Cornishcitroen
I am delighted to say that my Citroen C15D Turbo now goes and gets gears. Thanks for all your help chaps.
