citroen c5 hovercraft
darbuck
- x 290
- x 1240
Re: citroen c5 hovercraft
If you look at the driveshafts, the error will be approximately the difference between the height above the road of either end of the drive shaft, if the shafts look parallel the height is not far out. Check the distance from the top of the wheels and the wing and compare it with another one. If you have a Haynes manual it should tell you what the height should be.
darbuck
- x 290
- x 1240
They don't normally get out of adjustment unless interfered with or damaged so will be interested to hear what you find.
darbuck
- x 290
darbuck
- x 290
hilads just an update couldnt get under car safely so will have to hold off until i can get to local citroen indy will let you know how iget on adios for now
Darren
