Is my Heater Matrix on the way Out - Xantia S2
gadgetgricey
Re: Is my Heater Matrix on the way Out - Xantia S2
Unread post by gadgetgricey »
As long as your cable is intact, it only takes a couple of minutes to get at the heater controls.
Two torx bolts to remove the ashtray, and then four to remove the heater switches....
I was lucky as the assembly had failed and the cable was not being pulled by the unit. Disconnected it from the "unit" and then pulled to make sure it was open.
Then reassembled everything. Probably about 5 mins all in.
The flap is by the heater motor, as you can hear it opening/closing, but I never investigated access.
Cheers
Dave
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
