Xantia rear suspension
Chetiya Dias
Re: Xantia rear suspension
Unread post by Chetiya Dias »
Wow this is heavy. How to check for internal return leaks. Also what is the electrovalve and what to check with the pump and the regulator.
2000 Xantia 2. 2.0i 16v
Chetiya Dias
Paul my car is a non active version. Does this has an electrovalve
Chetiya Dias
Can some please mention about the electrovalve and how to check for internal return leaks. Thanks
x 3282
If you have a 6 sphere Xantia this means it is non-hydractive, which means it does not (to the best of my knowledge) have any electrovalves in the suspension system. The 8 and 10 sphere Xantias have electrovalves.
Just a thought. Is there enough LHM in the system? To check what you do is to park the Xantia on level ground, raise the suspension to its' highest position, and then take a look at the glass dome on the LHM reservoir. The orange disk (not the brass one) should be between the two red rings.
Chetiya Dias
Thanks James. Yes it has only six spheres and LHM level is fine. Do you have an idea to check for internal return leaks. If you go through my posts should understand my problem.
x 3282
I cannot help with it, as I have not experienced that problem before, so I have not had to investigate or learn the cause.
Chetiya Dias
Thanks James
Chetiya Dias
Hi everyone. This video was done starting the engine after one hour. Is the stop light taking too long to go off. https://vimeo.com/115704297
dei9
Unread post by dei9 »
Well from that video, the stop light CAN come on for issues OTHER than the suspension fluid being low. And it seems like you're low on engine oil.
The oil light goes off and the the stop light goes off after it.
(I don't know if the stop light is designed to come on when the oil is low too, my guess is it can, and in this instance it could well be the reason why the stop light is on!)
Top the engine oil first!!
The problem with your rear suspension playing up could be unrelated to the reason the stop light is on when you start the engine!
But seriously, if the engine oil low light comes on top it up!! Do it ASAP, it's imperative!
(I've never heard an alarm before, but I think it's an asian specification for your particular car).
...from Dei
1999 Xantia 2.0 Hdi 110 Exclusive (8396)
2001 Xsara 2.0 Hdi 110 LX Auto
x 94
Unread post by citronut »
the stop light and hand brake/fluid level/pad low warning light go out together, both after the oil lamp goes out
Regards, malcolm.
Chetiya Dias
When the stop light goes off only the car starts raise.
x 1983
Unread post by Stickyfinger »
Oh my, top up that engine oil pls Sir....I cannot believe your doing that :(
Northern_Mike
Chetiya Dias wrote:When the stop light goes off only the car starts raise.
It won't be rising at all if you don't put some oil in the engine!
Chetiya Dias
Engine oil level is fine.
dei9
Don't want to sound patronising.... u say it's fine (now), was it fine before?
have u actually checked it:
1 after warming the oil up after a good run (enough to warm the oil up)
2 after letting the oil settle for 10 mins after the run at point 1
3 when the car is level (do you park it on a hill or at it's side somehow to make the oil sensor trigger).
(still, I need someone else to confirm whether the stop light will come on when/if the oil is low)
Needless to say, if it keeps staying on like that for a few seconds after it starts you may have low oil pressure
...from Dei
