C5 2.0hdi vtr 2006 - depollution fault cold start trouble
wizaird
Locked user account
Re: C5 2.0hdi vtr 2006 - depollution fault cold start troubl
Unread post by wizaird »
Hi , this was fixed by fitting a new Injector .............as it eventually wouldn't start properly at all. RAC cam out and diagnosed injctor failiure.
Garage had the injector tested and it was a fail. New second hand one fitted and good as NEW !
thanks Dave
wizaird
Locked user account
Hi , this was fixed by fitting a new injector.
RAC dignosed a failed injector when the car eventually packed up altogether.
Hope this helps you folks
best Dave
darbuck
x 291
Unread post by darbuck »
Hi wizaird,
if she took in a lot of water the engine could be toast did you check to see if she's burning oil or does she sound unusual when you rev her i.e a bit clunky only I killed my engine last year same symptoms. I doubt it If theres not loads of smoke but surface water is a big problem with these cars due to the low breather. Just a quick tip for all if your breather flexi looks a bit iffy take it off and take off the rain coat and wrap the felt duct itself with silage tape or some other type of waterproof tape even wide insulation tape it just might save your engine because this is how mine took in the water. by the way wizaird id be very intrested in that afm by the way that you suggested in my other post. again i hope im wrong about the water
cheers Darren
Darren
wizaird
Locked user account
Hi thanks fro that infor ....if you ring me or text 0-7-7-8-8-9-4-0-5-1-1 I will let you know all you eed (part number ) for the MAF sensor or email wizzaird(at)hotmail.com
thanks Dave
darbuck
x 291
sorry wizaird ive had alot of problems with wifi for past two weeks so only got message and saw post today.what sheckles do you want for maf
Darren
