What is my C5 worth?
Mandrake
x 694
Re: What is my C5 worth?
Unread post by Mandrake »
If you're driving slow (30mph) and it's not too hot that you can get away with driving with the windows half down it would be more economical to do that than run the air con. If you're on the motorway though the aerodynamic losses from open windows would almost certainly exceed the power used by the air con compressor! (Not to mention the noise and buffeting drives you crazy)
As someone who used to live in a hot country and owned many cars with no air con or non-working air con, I know all about windows open at high speeds and very much appreciate working air con now! (Thankfully the air con in my new Xantia is exceptional and easily dealt with this weeks 28 degree scorchers... :) )
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
addo
Sara Watson's Stalker
x 95
Unread post by addo »
cpikey316_ wrote:My colleague told me a few weeks ago that he doesnt use his as he was told it decreases fuel efficiency by 50%!
He is terribly misinformed. A properly charged and maintained AC system uses only slightly more than bugger-all power. You can watch the instantaneous fuel consumption as you turn it on or off, to compare.
The cabin fan consumes power, but that is regardless of the air temperature passing through the system.
cpikey316_
Re:
Unread post by cpikey316_ »
I told him this, I dont know whether it will affect what he does. Most people in this country see AC as a pointless expensive novelty, hence the problem in finding a system in a budget car that works! :(
Light bluey 2002 C5 LX
addo
x 95
Well, if he's not willing to observe the easily seen effect on consumption via the trip computer, your man's a capital-P Pillock.
Tightarses need to realise that life is overall lowest cost for them, if they drop dead right away. :twisted:
x 1240
Unread post by Peter.N. »
My aircon doesn't work and I haven't bothered about it because for me its rarely hot enough to need it, although it certainly speeds up window demisting. I think a large proportion of cheap cars have non working aircon so I don't think it will make much difference to the saleability.
Northern_Mike
Well of course it affects saleability.
It's called air CONDITIONING for a reason. It's not simply air-cooling is it?
Enviado desde mi GT-I9505 usando Tapatalk
qprdude
x 14
Unread post by qprdude »
Don't be fooled into thinking the Honda Accord is bulletproof. There's no such thing.
Rick.
2013 Citroen DS 5 D/Sport
waynedance
x 8
Unread post by waynedance »
Air conditioning us so important to me that if it stopped working I would have it sorted the same day if possible. Come to think of it anything that stops working is fixed asap, hate thinks not working.
Volvo S80 D5.........
x 2943
cpikey316_ wrote:I am also of the 24/7 air con using variety! it annoys me that theyre usually broken due to negligence.
About 8% would be nearer the truth, same actually as driving with the windows down.
Northern_Mike
I don't notice any difference at all with the Berlingo. It does 46mpg day in day out, aircon off or on. It rises to 50mpg on a motorway cruise at 65mph.
Northern_Mike
Re: Re:
waynedance wrote:Air conditioning us so important to me that if it stopped working I would have it sorted the same day if possible. Come to think of it anything that stops working is fixed asap, hate thinks not working.
You must be always repairing a C5 then...
cpikey316_
Re:
Good thing with mine, apart from the air con, there are very few extras to break!
The car itself is fine, I just like air con!
Northern_Mike
Re: Re: What is my C5 worth?
qprdude wrote:Don't be fooled into thinking the Honda Accord is bulletproof. There's no such thing.
There is not, however Hondas do aseem to be more reliable than most things. My dad's Jazz has had nothing other than normal servicing in 10 years out in Greece. Not even an AC regas and it all works perfectly.
Friend of mine has an 07 Passat TDI. It failed in a way that meant it couldn't be recovered. Electric handbrake on, no power, tiptronic auto. Anyway, out of annoyance he asked the AA man what he never gets called out to. Answer - Hondas. Claimed it had been more than a year since he'd been called out to one.
waynedance
x 8
Re: Re: Re:
Yeah there has been a few things needed fixing.
qprdude
x 14
Brother-in- Laws 2008 Accord led him a life of misery toward the end. Rear suspension bushes were changed three times, rear shockers twice, tracking set up twice, window motor burned out, tail gate lock broke meaning he couldn't lock it. He did several resets (battery off) which got it working for a couple of weeks first time, then a week, then a couple of days. Honda quoted over £800 for a new switch/lock. It seemed to guzzle headlamp bulbs at one ore two every couple of months. He got rid and bought a 2012 E class Merc.
Seems like every manufacturer has it's bad boys.
I've had an air-con re-gas, new tyre monitor sensors and just recently a front off-side strut, all under warranty but even though, not a massive problem in just over two years of ownership.
Rick.
