I can find brembos easily enough. The handbrake but would worry me a little but then if the engine died and I needed to brake... Clutch and a gear would do at worst!
Well I'm going to order the bits next week but will be getting the calipers soon as well so will see what happens.
May change tack if a C5/c6 set come up cheap!
LHM brake seals
Northern_Mike
Re: LHM brake seals
I imagine it's an off-road or track car as you're not concerned about it bothering an MOT tester?..KP wrote:I can find brembos easily enough. The handbrake but would worry me a little
KP
- x 27
Re: LHM brake seals
It would bother the mot tester as citroen intended it. After that....
Though my distractions tonight have taken me off track as I plainly forgot the c5 stuff is useless for a xantia
Maybe an xm caliper is twin pot...
KP
- x 27
Re: LHM brake seals
Well the xm route is no good.
The 2.5 and v6 have the biggest front setup and they use a single pot caliper as well
Maybe what I think of doesn't exist in lhm land ;(
