Exactly what is happening. Can't hear the "bang" when driving my friends X7qprdude wrote: that my front suspension gives a bit of a bang if I go too fast over a "Traffic calming Bump" on the road. The rear never makes a sound.
C5 Hydractive3 front suspension low
osx
- x 15
Re: C5 Hydractive3 front suspension low
C5 X7 Exclusive 2.0 HDi Auto
osx
- x 15
Yes. I know that the front lowers when on the motoroway but this shouldn't happen when stationary. Good idea to check some photos from ones that are on salevborovic wrote:@ osx - Back on track ... if you lower/lift the car several times even ... when you return it to normal, does it stop at the current level that seems problematic to you?
They don't look lower at the front
http://www.autotrader.co.uk/classified/ ... ?logcode=p" onclick="window.open(this.href);return false;
and one that looks like it was left at the service position
http://www.autotrader.co.uk/classified/ ... ogcode=flp" onclick="window.open(this.href);return false;
qprdude
- x 14
Have to say, you've not picked the best pictures to show the car from the side. Always difficult to judge when shown from an angle. I looked at some from exactly side on when I said they looked lower at the front.
http://www.autotrader.co.uk/classified/ ... 9/usedcars" onclick="window.open(this.href);return false;
http://www.autotrader.co.uk/classified/ ... 8/usedcars" onclick="window.open(this.href);return false;
http://www.autotrader.co.uk/classified/ ... ogcode=hlp" onclick="window.open(this.href);return false;
Rick.
2013 Citroen DS 5 D/Sport
vborovic
- Locked user account
- x 40
Once again, can't someone measure his/her C5 X7 with hydractive suspension (from pavement to the top of the front wheel arch) and share the results here, so osx can compare that with his situation? I can measure from my car, but it has regular suspension ... but I'd think both suspensions should be on the exact ride height when normal and stationary ... no? You could also factor in the wheel size (the X7 does have a wide span of possible tyres fitted, from 16in to 19in), but it shouldn't make such an obvious difference, IMO ...
osx
- x 15
These look fine. Mine is at least an inch lower.qprdude wrote:Have to say, you've not picked the best pictures to show the car from the side. Always difficult to judge when shown from an angle. I looked at some from exactly side on when I said they looked lower at the front.
osx
- x 15
Could it be the spheres?
Mandrake
- x 694
Spheres don't affect ride height, so no.osx wrote:Could it be the spheres?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
osx
- x 15
What about LDS fluid levels?
qprdude
- x 14
Could be wrong, but I would have thought low fluid level would have an equal effect on all four corners.
Rick.
osx
- x 15
The front and back behave differently as for example the back will start rising first when you increase the ride height and the front will dip first when you reduce it.qprdude wrote:Could be wrong, but I would have thought low fluid level would have an equal effect on all four corners.
qprdude
- x 14
Yes, I know. I meant that low fluid level would affect the whole of the suspension system as far as heights are concerned, not just make the front lower.
Rick.
osx
- x 15
If the priority is to keep the rear at the correct height (makes sense as the rear suspension has to deal with variable loads) then you would expect an impact on the front if the LDS levels are not correct? Just a thought
