No Robert, the DRL option on your car will have to be enabled by a lexia session if it doesn't appear. Luckily, mine is already enabled. Some cars have it in the Vehicle parameters and some don't . I think it may be enabled as standard in the Exclusive, but there is a thread on here where some owners have had a lexia session to bring it into the menu (along with some other things).
The Citroen C5 DRL only light the fronts as far as I know (too lazy to check the rear!)
I'm 90% sure that the bulbs are already in situ as some owners have already enabled the option via Lexia, you just need the option enabled, then you can select it in parameters. I believe the bulbs are a horrendous price to replace though.
If you are thinking of a Lexia session, you might want to see if anything else can be enabled at the same time.
citroen c5 2.2 vtr plus
qprdude
- x 14
Re: citroen c5 2.2 vtr plus
Rick.
2013 Citroen DS 5 D/Sport
Robert12
OK thanks got my own lexia
Robert12
Hi mate do you now where to plug lexia in can't find it in glove box fuse box regards
qprdude
- x 14
No idea as I haven't got one, but if you pull away the rubber liner inside the front of the centre console storage compartment , there's a long(ish) orange plastic socket which you might recognise.
Rick.
Robert12
Hi are your day running lights on with your side lights
qprdude
- x 14
Independent as far as I know. I have them selected,and they are on at the front whether I have any lights on or not. My lights ate set on auto so the dipped beam comes on when the light is poor, or when the auto wipers come on.
Rick.
Robert12
OK mate will have another gow tonight I wounder. if there is an option to put windows up when locking
With key fob thanks Rob
mooseshaver
Press and hold lock button closes windows. What I would like is to be able to open them from fob like I could on the mk1
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
Robert12
Hi got the day running lights on now thanks
qprdude
- x 14
Rick.
KP
- x 27
Try holding the unlock button down for longer and see if they go down
Works on a lot of modern cars just as the holding of the lock button closes them
mooseshaver
True but no joy. Also tried sticking key in and turning.KP wrote:Try holding the unlock button down for longer and see if they go down
If I had nothing in the boot I could just use the boot opener to cool down!
Gone cars.
Gone cars.
Robert12
Can't get phone to connect to Bluetooth in the car engine of ignition on Do a search on my phone nothing? Any help thank you
