Picccy Clutch
flying clutchman
x 3
Re: Picccy Clutch
Unread post by flying clutchman »
That only leaves 3 then, bearing not seated on the arm properly. Very easy to do as they are only tiny little retaining clips.
x 94
Re: Picccy Clutch
Unread post by citronut »
another thought :idea: :idea:
did you re/fit the clutch actuator arm back onto the fork spindle in the same orientation it came off from/in?????
at least if this is the case you wont need to drop the box off to fix it [-o< [-o< :wink:
Regards, malcolm.
shane25
Re: Picccy Clutch
Unread post by shane25 »
citronut wrote:another thought :idea: :idea:
yup and also changed ot for a known working 1.
ive just been trying to avoid pulling the box as they seem to be a bitch on these.
shane
ps thank you for all the replies
