S1 Xantia, alarm problems....
Mandrake
x 694
Re: S1 Xantia, alarm problems....
Unread post by Mandrake »
citroenxm wrote:S2 alarms do not have a key cut off under the bonnet. It was deleted. There should be a red led that blinks of the drivers door and little ultra sonic sensors on both doors
Check the topic of the thread again or the original post... :wink: :lol:
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Thanks mandrake but if you read back you will see that tim said his SERIES 2 doesnt seem to have an alarm so in typical fcf fashion the topic has switched to s2 alarm discussion. :wink:
A very sad...
1994 XM 2.1 d auto
lankytim
Unread post by lankytim »
Nope. None of those things are fitted to my S2. No wonder the alarm didn't go off when it got broken in to. Is it possible to retrofit an alarm from a "normal" Xant?
citroenxm
Fallen Hero
x 70
Not a factory xantia alarm probably not.. it would have to be an aftermarket one.
This is because its all linked into the cars ecu the indicators the door locks.. in saying that the harness plugs could all be in place ready and it might be a case of plug the box's in and see..
A very sad...
1994 XM 2.1 d auto
Mandrake
x 694
On a Series 2 Xantia the alarm is part of the CPH / Texton ECU that controls central locking and immobilisation, its possible to enable and disable the alarm feature permanently with a Lexia, so potentially you might be able to fit the missing bits like the sensors/wiring/siren etc then enable it with a Lexia.
You can monitor the state of the input sensors for the alarm such as door switches with a Lexia, it would be very interesting to put a Lexia on a S2 Xantia that doesn't have an alarm and see how much alarm functionality still exists in the CPH, and whether it is already wired up to door switches etc, If it has the same configuration options as a model with an alarm its probably just the lack of the external hardware being connected and the alarm functionality being turned on in the CPH.
Simon
1978 CX 2400
lankytim
Well the wiring for the alarm cancel button is already there so you never know..
citroenxm
Fallen Hero
x 70
Again.. let me know. Ive got all the boxs and bits from the s2 green sx xantia i dismantled..
A very sad...
1994 XM 2.1 d auto
