c8 automatic gearbox (al4) issues
- x 8411
Re: c8 automatic gearbox (al4) issues
Excellent stuff Aaron
Watching and reading with interest...
Mandrake
- x 695
I'm watching with interest too and hoping for a positive outcome.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
arronmc
as of right now i have the subframe , steering rack etc off the car the box is on with 2 bolts only i need to get the o/s shaft out and its ready to come out as i said earlier the oil pump etc is out of the donor box ready to go in and after stripping the subframe from the car that will be the easy bit
atb arron
atb arron
arronmc
right i got the oil pump and filter changed yesterday and its working fantastic now not sure if the pump was faulty or if it was just the filter i changed both when i had the box out , i still have a few jobs to do but it will have to wait a few days as the o/s front spring snapped when i had my hand in there jamming 3 fingers against the seat of the shocker i had to get a power bar to prize them out (now thats a freak accident if i ever saw one lol) and ive shattered the end bone in my ring finger off to see the surgeon in an hour or so . once again i would like to thank citrojim for all the invaluble advice and hopefuly my experience can help some one else with similar symptoms
atb arron
atb arron
Mandrake
- x 695
Geeze mate, sorry to hear about the finger!
Excellent news on the gearbox though
Hopefully no dirt got into the oil ways or inside the gearbox while you were working on it. Even a tiny bit of dirt can gum up the valve block and cause major problems. Was the filter really blocked or did it look ok ?
Simon
1978 CX 2400
1978 CX 2400
- x 8411
Ohh nasty on the finger Aaron but excellent news on the 'box..
Hope the finger is soon sorted out
arronmc
they said i was lucky it didnt take the end clean off i cant lift anything heavy or put strain on it for 2 weeks and i cant bend it but it will be fine and all the pieces are in the right place , the filter didnt look to bad but i didnt prize it open so its hard to tell im just glad its running again
atb arron
atb arron
- x 3296
OWW! I bet the car learnt a few choice words! Take it carefully, you don't want to hurt it again.
Barring the injury, well done on the 'box. Keep going (when you are able to), you'll get her there.
arronmc
right i now have the car built back up (with a pair of new coil springs on the front) the car is driving lovely the only thing is the esp light is on there are no fault codes coming up just the light and the message on the dash saying esp faulty any ideas would be gratefuly recieved
atb arron
atb arron
arronmc
the esp light was just because the steering wheel was 360 degrees out because I hadn't realised it had turned when I had the rack disconnected it is now fully built back up and working 100% I hope this thread will be of some help to someone else in the future ,
thanks goes out to all that helped especialy citrojim who has excelent knowledge of these boxes
atb arron
atb arron
- x 3296
Congratulations on a job well done, setbacks and injuries notwithstanding. Your experience (and write up) almost certainly will help others.
1inchwarrior
- New User
I have had a very similar problem with my AL4 gearbox, http://www.aussiefrogs.com/forum/peugeo ... blems.html" onclick="window.open(this.href);return false;.
Having been trawling the tinternet looking for some an answer I stumbled across this thread and so with your success I may just have to try the filter / pump change my self.
I have a rebuild manual however I have no idea (yet) what the beat method is to take the gearbox out. Any help/ advice / links would be much apreciated.
Peugeot 306 1.6 Meridian AL4 Auto
Frenchtranstech
Your p/solenoids are getting stuck or still a little sticky for sure ,it's not the oil pump it's not the clutches or bands,I sell in Australia my own design modified super slippery solenoids that will fix all your problems. If your interested my email is tonyandryan at msn dot com
Pözho
Hey Arron,
I was reading your story with excitement. By the way, hope your hand got well after all that!
Myself I'm fighting with the AL4 on my Peugeot 406 HDI.
Long story short: 2 days after I bought it went into gear box fault (on a steep hill).
Next day the faults became more often until it stopped driving after about 50km.
What I've done so far:
Replaced both solenoids, dismantled the valveblock and cleaned it, cleaned the small filter in it, changed the oil.
Nothing has changed.
When I read out the parameters with Diagbox the problem is the oil pressure.
When I start the engine, the oil pressure is for the first 10-20 seconds, car drives perfectly.
Then oil pressure drops and the car doesn't drive anymore.
If I restart the car it drives again perfectly for 10-20 seconds.
It seems to me like there is a sock in the sump which blocks the oilflow.
But this is just a feeling. I'm afraid the oilfilter is burst/ clogged or the oil pump is defective.
Any comments on that?
Thank you,
Rod
Thank you,
Rod
Mandrake
- x 695
Sounds exactly like the symptoms I saw here:Pözho wrote: When I read out the parameters with Diagbox the problem is the oil pressure.
http://www.frenchcarforum.co.uk/forum/v ... =3&t=41417" onclick="window.open(this.href);return false;
Unfortunately there was no resolution to the problem on that car - the owner scrapped it.
Simon
1978 CX 2400
1978 CX 2400
