Headlights
Citroening
x 19
Re: Headlights
Unread post by Citroening »
Interesting - thought I was wrong...! :lol:
Now I wonder who told me it was a temp sensor... :-k :wink:
Franklin
x 5612
Re: Headlights
Can you test the resistor as it may not be that that is faulty, there will also be a relay somewhere for the logic.
The dimdip should only work with the side lamps on and the engine running. engine off - side lamps only.
Check the resistor is not open circuit then see if there is a voltage applied to the terminals with the engine running and side lamps on.
Diabolical
Re: Headlights
Unread post by Diabolical »
Yes it is Dim Dip resistor. There is one fitted to all CX's Single and Bi Optic., the temp sensor is behind front bumper little to the left, cable goes down under the battery.
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
jwalshe
Re: Headlights
Unread post by jwalshe »
Fitted a new dim-dip resistor - all is fine! On sidelights, the main lights glow nicely as Citroen intended with the ignition on.
Thanks for your help! :-)
Diabolical
Re: Headlights
jwalshe wrote:Fitted a new dim-dip resistor - all is fine! On sidelights, the main lights glow nicely as Citroen intended with the ignition on.
I've had 2 CX's with single optics and they didn't glow, must have been faulty dim dips on both.
Learn something new every day.
Shortly I will be putting up for sale 2 single optic lights in very good condition.
citroencx.co.uk
