C5 mk1 estate Electric shocks
qprdude
x 14
Re: C5 mk1 estate Electric shocks
Unread post by qprdude »
Ah, OK Peter. Never had a problem with static in a car. The only time I can remember is from an escalator moving handrail once or twice.
This means of course, it has less to do with the car, and more to do with the seats and clothing right? I guess some people must be more susceptible than others then.
Rick.
2013 Citroen DS 5 D/Sport
Mandrake
x 694
Unread post by Mandrake »
Yep, seat material, clothing, shoes and humidity are the main factors.
I've only had maybe one or two shocks from the doors on my current Xantia and I put that down to the leather seats versus fabric, although the air tends to be a lot wetter over here too... ;)
The humidity must be low for a static charge to build up and its friction between the seat and your clothes where the charge builds up. (Think of a plastic comb and a balloon) Even if a charge builds up you generally won't be shocked if the soles of your shoes have poor insulation because as soon as you put your foot on the ground the charge bleeds away gradually (over a second or so) without shocking you. If your shoes have thick high quality rubber soles with good insulation the charge won't bleed away to the ground - that's where you'll tend to get a good shock. So its highly dependant on the kind of shoes you wear whether you'll get a shock.
Keeping your hand on the door as you get out causes the charge on your body to bleed away slowly through the body of the car and the tyres to earth. (Tyres have impurities in the rubber and tend to be dirty so aren't as good an insulator as a good pair of soles on shoes)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 1240
Unread post by Peter.N. »
I have probably only experienced this a couple of times in nearly 50 years of driving, once was in a Vauxhall Velox with vinyl seats and I can't remember the other but exceptionally dry weather sets the stage for it. If you home is also very dry your clothes will be to, any synthetic clothing will complete the scenario.
qprdude
x 14
Good job I wear only the finest lambswool , Leather shoes and silk shirts then.
Rick.
x 1988
Unread post by Stickyfinger »
Just do not put these on !....deadly sparks !
ej2095
Unread post by ej2095 »
Stickyfinger wrote:Just do not put these on !....deadly sparks !
lol passion killers
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
isisalar
x 3
Unread post by isisalar »
Experienced this static frequently when I was in the motor trade. Brand new cars seemed to be far more prone than others oddly. The combination of new car, stored in the sun, nylon velour seats, polythene seat covers and certain footwear would produce quite violent shocks with visible sparks, until I adopted the feet first and earth system outlined by Simon. Haven't noticed it for years.
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
x 1988
lol passion killers
Not in my world :), add nylon sheets and watch her eyes light up like a pin ball table !
Old-Guy
x 24
Unread post by Old-Guy »
Try fabric softener in the wash - they're all claimed to reduce static!
