Activa plumbing!
djadams
x 14
Re: Activa plumbing!
Unread post by djadams »
andmcit wrote:That bush / ally housing is around £30 all in.
Wow - OK, agreed, that's really not so bad. If the dealer quote me that price I'll happily order one in and quit complaining :-D Thanks for the good news!
I'm consoling myself with the thought that for the bush to have failed whilst I was gently easing things around fitting the other mount it must already have been very nearly shot :dunno:
As for the leak, there really isn't much LHM high up, the junction near the return pipework connector that was leaking really does appear to be the epicentre (or perhaps just near the epicentre... who knows...! :? :dunno:)
2000 Xantia Activa 2.0 TCT (Danowned Activa :D daily driver)
1968 DS21 Pallas BVH (high days and holidays)
mirafioriman
Unread post by mirafioriman »
If it's a high pressure leak it's worth checking that all the unions are tight. I've noticed on mine many tightened up quite a bit with a spanner.
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
djadams
x 14
Right then... New engine tie-bar mount/bush thing ordered and collected, along with a new dipstick (as the one with the car was missing the bit of the handle that goes down the tube and seals it). Sure enough, the mount was less than £30. Those will hopefully go on tonight...
Meanwhile, new pipe seals finally collected from GSF and as I'd left the car up on stands, I had a quick look at fitting one to the joint I'm suspicious of. Sadly, the back-nut is tighter than I fancy trying to undo with an open-ended spanner, I only have flare-nut spanners down to 9mm and Halfrauds don't carry an 8mm flare wrench. So, I've just ordered a Britool one off ebay for £6 delivered, but will have to wait for it to arrive before having another tentative go - the last thing I want is to round off the flare nut! :twisted:
Meanwhile, one of the nuts on that union was slack enough to undo with an open-ended spanner, but having unscrewed it from the union, I couldn't then get the pipe out to replace it's seal... Surely these normally slide in and out really easily? What does it being really hard to shift imply? :shock:
Chris570
x 36
Unread post by Chris570 »
It's french, once you get it out you'll see why it was hard to get out. they arent all that easy to do, even on the bench. Nothing to worry about. you'll swear at it for a while and then it'll fall out
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
djadams
x 14
Chris570 wrote:you'll swear at it for a while and then it'll fall out
Right, I'll just have to quit being such a pansy with it then... :-D
Once I've got my 8mm flare wrench, I'll pull it all apart, and probably wish I hadn't... :lol:
Deanxm
x 87
Unread post by Deanxm »
It help to gent ly wiggle the pipe side to side or in a circular motion to uncompress the rubber seal and then it should slide out easily, carefully fit the new seal into the port and then slide the pipe into it on reassembly.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 3296
If you need a small flare spanner, somebody in another post suggested cutting a 5mm slot (using an angle grinder) into a ring spanner, converting it into a flare spanner. Combo spanners are quite cheap.
x 8385
Hell Razor5543 wrote:If you need a small flare spanner, somebody in another post suggested cutting a 5mm slot (using an angle grinder) into a ring spanner, converting it into a flare spanner. Combo spanners are quite cheap.
That's good idea that. Even better is to do the same with a 1/4" drive hex socket and weld a short handle onto it. A good well-fitting socket with a hex rather than a bi-hex is the very best tool for really tight and stiff 8mm unions which I've known to round off even when using a hex flare nut spanner.
djadams
x 14
Delayed response, but all seems well now - the 8mm Britool flare spanner turned up last week and was put to good use splitting the joint and replacing a seal. The side I thought was leaking came apart easily enough once the stubborn back-nut was persuaded, and the seal inside seemed rather distorted. Put back together with a new seal and all seems well so far. Nice nice...
x 8385
Excellent stuff :-D If only all Activa leaks were that easy... :twisted:
djadams
x 14
:-D
I now have a new Activa challenge, which deserves a new thread...
6speedmanual
Unread post by 6speedmanual »
Dan
The bush is not available separately.
However, as the bush is small and very hard rubber and the other end of the link is into a big softish bush, I reckon you could find a solid turned nylon bush would be almost as good and longer lasting (if 100K miles is not enough LoL)
Do you have access to a prototype machine shop? I thought I saw somewhere you are in Vehicle engineering?
x 3296
IIRC CitroJim has managed to make Activa bushes in the past. It probably is worth asking him what he used, etc.
6speedmanual
Yes, the same black nylon/nylatron material would suit.
Actually my Activa (Xantia 3rd Millenium) has a "Jim" style bush at the rear CAR ram. Wondered if it was one of his when I saw it.
x 8385
yes, it will be. I supplied Captain Slow with one...
The details on how to make one are here...
