Recommended Winter tyres and suppliers
djadams
x 14
Re: Recommended Winter tyres and suppliers
Unread post by djadams »
I fitted 185/65R15 Continental Winter Contacts to my '95 Xantia 1.9TD back in 2010 when I was living in Ashbourne and working at JCB. TRANSFORMED the car in winter, and not just in snowy conditions. I'm sure I only paid about £60 a corner from kwik fit which seemed a bargain and I've not seen anything close to that price wise since. I chose them because I'm generally a fan of Conti tyres and have used them on push bikes, motorcycles and cars for years. I can't say I'd particularly choose kwik-fit, though in fairness they vary greatly from branch to branch. The Leamington Spa branch recently proved themselves clueless about jacking a Xant and declared that the suspension had broken when they couldn't get it to rise after putting the lever fully forward for reasons known only to themselves... :roll:
The following spring I fitted a secondhand set of C5 alloys with part-worn (205/60) summer tyres and left the winters on the OE steel rims. The winters went back on last winter, and following the demise of the TD (sad days :() the slightly undersized Conti winters have now gone onto my newly purchased Activa (which "should" run on 205/60s). It drives beautifully on them and sticks to cold wet roads road like glue, though the speedo is now even more optimistic.
I've also had good experience of Nokians whilst winter testing various vehicles (I play with prototypes for a living) and studded Nokians are often the tyre of choice for blatting around on frozen lakes in the north of Sweden or Finland at -25°C.
2000 Xantia Activa 2.0 TCT (Danowned Activa :D daily driver)
1968 DS21 Pallas BVH (high days and holidays)
Xantidote
x 4
Unread post by Xantidote »
djadams wrote:I fitted 185/65R15 Continental Winter Contacts to my '95 Xantia 1.9TD
I fitted exactly the same tyres (TS 830) to my 1995 TD last winter. They were pristine, used in 2010/2011 winter by original owner, and he'd also bought them from Kwikfit - I think they had a special deal on at that time. Unable to comment on performance, as subsequently I hardly encountered any snow last winter, as it turned out. Felt I needed them, due to meeting family commitments.
Fitted the TS830s to a set of steelies off a 2001 Xsara Picasso. They were 6J with 18mm offset, whereas my Xantia's OE steels are 5 1/2J, with 15mm offset, but no problems experienced.
Martin
1995 Xantia TDLX (deceased :( )
Old-Guy
x 32
Unread post by Old-Guy »
A set of Goodyear ULTRA GRIP 8 185/65 R15 88T ordered on Monday ("ex stock" from a local supplier), intending to fit them today.
Phone call Wednesday afternoon to say they won't be delivered until Friday as they have to come from Germany.
So that'll be "ex stock" from Goodyear's factory :roll:
Slightly inconvenient, but then it may mean they will be almost hot out of the moulds, I'll check the date code(s) when they arrive.
