were'z that D section
x 5684
Re: were'z that D section
Malcolm is right,there is a unattached pipe there too.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It's for measuring backpressure. I have a bung in the exhaust, pre-cat which is presently plugged. The tube screws in there and I connect a pressure gauge to the top and rest it on the scuttle for driver's visibility.
Due to prolonged high heat, the rubber tank cap seal hardens and allow creep of the oil. The top of the tank also caves in slightly.
Here's the "D Section" Malc:
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
myglaren wrote:Malcolm is right,there is a unattached pipe there too.
addo wrote:It's for measuring backpressure. I have a bung in the exhaust, pre-cat which is presently plugged. The tube screws in there and I connect a pressure gauge to the top and rest it on the scuttle for driver's visibility.
Makes sense, I took the black pipe at the back to either be the LHM overflow or a rubber sleeve for the bowden cable.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
