glow plugs staying on all the time
jgra1
(Donor 2021)
x 36
Re: glow plugs staying on all the time
Unread post by jgra1 »
timing sounds about right there Sean..
I think they switch off at 60°C / or when throttle is beyond about 40%
John
spider
x 77
Unread post by spider »
The post heating is mostly controlled by the load lever on the pump.
If you can, unplug the microswitch on the pump temporarily. This controls (varies on model) the EGR, the post heating (as its shut off once the control arm is open a few mm) and / or the timing advance solenoid but this last item is also controlled in some cases by a switch on the waxstat cable.
I'm just thinking that the microswitch may be shorted and seems the easy test method to unplug it, if practical. It would probably be fine without it anyway...
Andy.
x 94
Unread post by citronut »
if the timmer is working correctly now, you might find the link lead between the glow plugs has got heat damage in the crimpt terminals, this will give a bad connection so will cause the cabl;e to get hot, as it cant pass enough current
Regards, malcolm.
sean86
Unread post by sean86 »
sorted put in a new cables no burning yet anyway. starts first pick. nice 1 thanks lads.
02 xsara 1.9
98 106 gti 1.6
99 xsara 1.9
98 xantia 1.8
95 405 1.9
x 94
good to here it sounds like your sorted
Regards, malcolm.
