Dreaded front suspension rattle, HDI 110
Jeff
Re: Dreaded front suspension rattle, HDI 110
Unread post by Jeff »
I had a knocking noise that sounded like a vertical mounted board banging when going over bumps, actually was N/S drop link.
I have changed the N/S but should I change the off side as well?
Also, would a faulty drop link cause a C5 to pull left slightly. I notice this is still a problem after changing the N/s drop link but when crusing on the motorway the car does not seem to pull to the left at all?
Thanks Jeff
Currently driving Citroen c5 2.0 HDI 51 Plate
Jeff
Bumped to top... any advice please?
harryp
(Donor 2022)
x 73
Unread post by harryp »
Well!! Although everything pointed to the o/s, I decided to change the n/s drop link - and yes, it stopped the rattle. I suppose over 27K isn't too bad, but I would have thought that they should last 4 times that! I did find that putting a long ring spanner on the affected lower nut did show up play and when removed the joint was very loose, but then It really did rattle.. Converesly, when the originals failed at 90K, they were very stiff. I seem to be learning at an ever increasing rate.
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
taffy
Unread post by taffy »
one noise ive had like this apart from drop links ball joints is i once forgot to put the spring back in the brake caliper and as ive had droplinks go before and know the symptoms i had exact same noises lol
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
