Xantia activa problems with height
robin92
Re: Xantia activa problems with height
Unread post by robin92 »
I cleaned the rear heightregulator today but...
Uploaded with ImageShack.us
But for some reason did not rise: S Then I took out a pipe of heightregulator started the car no oil ... I pressed a little on the regulator and the oil comes from the connection I have removed the pipe. Tested to stop in a thin wire, stopping after a few cm type of bump on the tube. . screwed it back. Started the car and it rasies to heights (I thought now it's finally evening and time to sleep at almost 0:30), but I try to lower the car and it does not! Releasing the pressure lifting up the car and screws on all 3 tubes. 2 of 3 injects the oil out but the 3rd as I released (the longest pipe, not the short as you can see where they go.)
Need help AGAIN! :/
Xantia Activa 2.0 tct -96, Xantia Activa v6 - 00
Sorry for my bad English;)
