Horn not working
isisalar
- x 3
Re: Horn not working
Thanks Richard. I may well give you a call.
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
- x 2941
Fitting a replacement horn is about the most basic of electrics you'll ever find, you'll have more trouble with the rusty screws than the wiring.
there are only two wires, a live from the horn push (When someone is pushing it) and one to earth.
There are plenty of cheapo ones available, have a look on Ebay or at your local motor factor.
Here's an example http://www.ebay.co.uk/itm/12v-CAR-HORN- ... 41609b36e5" onclick="window.open(this.href);return false;
Just one word of warning, if you're replacing a single horn just to that, if you're adding extras like loud twins or air horns you'll need a relay in the system to stop the horn button contacts getting damaged.
Fenderblender
I'm having trouble with my 2010 C5 HDi VTR+ NAV which has developed an intermittent horn failure. Can anyone tell me where the horn is hidden as I can't find the thing, I'm suspecting it has dirty or loose contacts which should be easy to fix?
SaabC5
Front of car, under left n/s wing area. If you take the undertray off you'll see the twin "snail" units.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
