Berling van gear linkage
x 8457
Re: Berling van gear linkage
Activa_Mike wrote: Does replacing the bits make it a floppy one less floppy? Or do "they all do that sir"? I can't remember what the linkage was like on my 98 model 1.9D new, it's so long ago..
On the 205GTi which used an almost identical setup, the major cause of floppiness was the bolt that secures Item 5 to the subframe coming loose and wobbling all over the place. Play in the clevis and its bushes under the gearstick will cause a bit of vaugeness too. Nothing else seems to wear much, even the rubber ball...
dave28
Unread post by dave28 »
Hi all just a quick update van all sorted the bolt had sheared of the end of the main rod that connects to the gear lever i just took the rod of and got the bolt welded back on hope it last but not a very good design very weak i know that they are different now as in pic three anyway cheers for all your help
x 8457
Excellent news Dave :-D
